Is ATV toast
Old Sep 4, 2017 | 06:53 PM
Had more problems with the flywheel coil versus the flywheel itself. The old style like you have and what was used on our early KTM 50 is NLA,but updated ignitions are offered at these two places.Morini Franco USA Morini Franco Ignition S5, SC and S6 Ignition System
Old May 23, 2018 | 06:50 AM
firsttimerider's Avatar
Default black dragon ignition
I bit the bullet and purchased the Black Dragon ignition kit for a 1999 Lem. I installed it exactly as instructed even though the instructions left a little bit to be desired. I did all the checks that was recommended. Still no spark. Has anyone had as similar experience? I've emailed the company but no response.
Attached Thumbnails Is ATV toast-img_0177.jpg   Is ATV toast-img_0178.jpg   Is ATV toast-img_0179.jpg
Old May 30, 2018 | 10:00 AM
Default crankshaft rotation
On most motorcycles the kick start pushes the pedal down to the back. On the Lem ATV, the kick is down and forward. The crankshaft viewed from the right side of the ATV rotates clockwise. I am wondering
1) if the Lem Motorbike kick starts the same way or does it go down to the back like other bikes and
2) does the motor bike crank rotate clockwise or anticlockwise?
Old May 31, 2018 | 05:43 PM
Default resistance
Using the Black Dragon Ignition. Does anyone know what the resistance should be for the primary and secondary coils?
Hossola
Jul 27, 2017 03:21 PM
joethegasman
17
Jul 4, 2017 05:07 AM
Chaaaales
Jun 14, 2017 09:02 AM
