S.O.S. Another ?
Old Jan 24, 2003 | 08:07 PM
Panamaniac's Avatar
Default S.O.S. Another ?
My speed is havinng back fires and after that hapens its stops. also all the bolt of the front disk went loose. is that normal or my speed is one of those monday´s bike.
can the back fires be the spark plug
thanks
Panamaniac.
Every time I use my speed something goes wrong.
Old Jan 24, 2003 | 09:27 PM
mxmike's Avatar
I would sa yea you got a monday bike,lol.
I would check the 8mm-12point nuts that bolt the head pipe to the head.If they are loose it will back fire after you let off the gas.I would also go through ALL your nuts and bolts and add lock tight to them.I havent heard of the front disk coming loose before.Defantly lock tight everything!!!!!!!!!
Or it could be a fould plug causing the backfire.I had that happen on cold starts before.
