Land, Trail and Environmental Issues Discuss political and social events effecting where we ride. Do not enter here unless you are willing to disagree with the statements made. What happens in this forum and Sub-Forums stays in these forums.
Tree straps
Old Dec 12, 2007 | 11:40 PM
jleo's Avatar
Default Tree straps
What is the difference between a tree strap and a regular tow strap? How do tree straps protect the tree?
Old Dec 13, 2007 | 12:13 AM
Dennislinden's Avatar
Default Tree straps
K not sure if this will help there r 2 different type of tree straps 1 is for hunters (
keeps them (me!!) from fallin' out of Tree's the other is used by landscapers, etc.. while using skidsters to pick-up & plant Big tree's.......That I Know of.? Dennis
Old Dec 13, 2007 | 10:51 AM
deanz400's Avatar
Default Tree straps
tree straps are what you use around a tree your useing to winch your Stuck butt out of a mud hole , a tow stap would work to the idea is to not injure the tree ,and have the tree huggers hunt you down
Old Dec 13, 2007 | 03:10 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Default Tree straps
Anything that you can use to protect the tree. Winch companies all sell them with nice nylon straps and D rings on both ends. Usually about 5 to 6 ft long. The wider the strap, the better.
Old Dec 17, 2007 | 09:17 AM
trailbound's Avatar
Default Tree straps
In a soft tree when you winch around it with the cable you can pull the cable into the tree both sticking the cable and harming the tree. A simple tree strap as described above will help to prevent both. I use a tow strap with clevisis on both ends.
You can actully kill a tree by cutting the bark all the way around the tree.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
caveeagle
Sep 19, 2015 01:20 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
