ATV Trailer
Old Sep 23, 2003 | 09:24 PM
400PrarieXLT's Avatar
Default ATV Trailer
Definitly check the local papers, I got a 7x8 with galvanized frame, sheet steel bed and tubular steel rails for 150 bucks. I sunk another 100 bucks in it with bearings, seals, bearing buddys, lights, paint and truck bed liner coating. Its pretty nice now. Kind of heavy, but I can just fit two quads on it with room for a storage box. If you can get something with built in ramps, you will thank youself. Thats my next add on...
Old Sep 24, 2003 | 11:14 PM
MikeCer's Avatar
Default ATV Trailer
You should be able to find a 4x6 trailer in your local town for about $300.00
just big enough for one ATV
I got one from this place
Trailer
payed $350.00
Old Oct 7, 2003 | 01:17 AM
nixnutz's Avatar
Default ATV Trailer
cheap and easy
http://www.harborfreight.com/cpi/cta...CategoryID=441
Old Dec 3, 2003 | 10:54 PM
BigRed1's Avatar
Default ATV Trailer
I need help, I am looking for a cheap atv trailer. I am tired of messing up my new truck. Thanks for your help.
Old Dec 3, 2003 | 11:01 PM
  #15
Foxracin's Avatar
Default ATV Trailer
Who needs a trailer just ride it on the road if you are not going far I do it all the time
Old Dec 3, 2003 | 11:22 PM
  #16
BigRed1's Avatar
Default ATV Trailer
Where I live I can't ride on the road. I do not get alone with the police since my brother has quit the force. so they are hard on me. Plus I travel were I go ride at anyway. well I got to go to work. you all have a good night.
Old Dec 3, 2003 | 11:33 PM
  #17
Foxracin's Avatar
Default ATV Trailer
Good luck at work
Old Dec 7, 2003 | 01:17 AM
  #18
Bobman's Avatar
Default ATV Trailer
Another resource for small trailers is golfers. The small trailers used to pull golf carts are great for singel ATV's. Go to the golf course and place a "wanted ad" on their bulletin board. It may yield something also.
Old Dec 7, 2003 | 01:54 AM
  #19
Spanxkx's Avatar
Default ATV Trailer
Originally posted by: NYC
This one is pretty nice, I jus got it.
It's Not that big, But it can be.
Take a look... I got it from Home Depot.
IT's about $599.
SnowBear
Go to Trailers & it's the 8000
i have the same trailor.. very nice! I highly recomend it.
Old Dec 7, 2003 | 04:36 PM
  #20
pearsth's Avatar
Default ATV Trailer
Hey,
I ended up buying this trailer as well. For those of you that have it, did you find the same downside that I did? Basically, there is nowhere to tie down to when the sides and front tailgate are on! If you leave them on, you have to tie down to them directly (bad, they started to flex), or have the straps on the provided lower tie downs on the bottom which caused the straps to be tight against the sides/front tailgate. Again, bad.
So, I now only have my rear tailgate on and am going to install some new recessed loops on the metal floor to tie down to. Is that what you did?
Tom
