no muss, no fuss oil change
As anyone who runs a full length glide plate on their 4 stroke knows, changing the oil can be a miserable, time consuming chore. I just received and used a new product called the Pela Oil Extractor which makes it an easy job by vacuuming the oil out thru the filler hole. I seems to extract as much, if not more oil than the conventional way. & the container holds slightly more than 1 1/2 gals.I learned of this labor saver from an article in the current D/W magazine under "Hot Set-ups"
the Az Hard Packer,
calmiller@kachina.net
the Az Hard Packer,
