Fuel Container for ATV
I found it a little difficult to find any fuel containers on cabelas.com , but finally did locate the fuel tank made to be carried on an ATV rack On This Page.
Alternatively you can get a common marine type fuel tank with a capacity of 6 gallons, Here's One Example, which still has a low/wide shape good for securing on an ATV rack, at less than a quarter of the price of the 3.28 gallon tank on cabelas.com specifically made for an ATV rack.
I was going to get one of those.. but for $90 for 3.3 gallons - that is a complete Joke!! I have a 2.2 gallon plastic gas jug that cost a mere $9. It has about 150 ride miles on it and hasn't leaked once! I keep it full almost to the rim, so not much sloshing...
Woodrat, you can even get Tempo's 3 gallon tank which would be smaller than the 6 gallon.
Yes, I see the 3 gal. tank made by Tempo, and there's a similar one made by Moeller Marine Here.
This shape which makes them stable on a small boat is certainly better for strapping down on an ATV rack than the typical upright gas can ... at least it's a sensible solution as far as economical mass-produced fuel jugs go!
Sorry not meant to Hi-jack thread
Hey Woods.. I haven't fallen into the ATV Accessory trap... IE Expensive Hardboxes, Gas Tanks, Expensive Rims etc... Even some of the ATV armor out there.. especially Yamaha accessories are prices just a bit crazy high...
I see you use your ATV for logging, you might want to use a chain around the log instead of wrapping your winch cable around it and hooking back onto the cable. Your cable won't last too long if you keep doing that. You could also use a tree-saver strap and a D-shackle. Northern tools has a great selection of them and I would get the D-shackles from Ebay
Northern Tool - Tree saver strap
Ebay D-Shackles dood WorkRambo
1/2" D-Shackles - CHEAP! But GooD!
You may even want to consider some ****** blocks (pulleys) so you can do more of a straight pull on with your winch cable.
2.8T Pulley
I modified the hook end of these pulleys by removing one of the "E" clips and cross drilling a 1/8" hole and installing a hair pin cotter. That way I can quickly remove the hook to run my winch cable through and then hook up to a Tree-saver strap to re-direct the winch cable...
Look at my pictures in my gallery - I have an example of when I used all my goodies to "Right" my quad
-Steve
2.8T Pulley
-Steve
Thanks CraZySteve, you're right, but I didn't have a chain with me the day I took those pics, though I have several. I"m not worried about hurting the logs which I'm cutting up for firewood, but I do carry a sling when trail riding.
Another option...you can get a Tamarack Low Center Front box--it has optional fuel cans or coolers--so you can use it for fuel one time and food/beverages another. Very practical. And check out the testimonial page on the website--this stuff will last you forever. (2 year warranty--where else in the ATV business to you see that?) You can see the box here and the gas can and coolers here. Good luck in your search! [img]i/expressions/face-icon-small-happy.gif[/img]
