Winch Question
Old Aug 23, 2007 | 08:42 AM
BAIR's Avatar
Default Winch Question
I move my Suzuki 450 around in a trailer.
The dealer advised me to put an eye bolt in the floor of the trailer and use the Winch (WARN 2.5) to hold the bike in place and compress the shocks.
OK - I did it and it works.
BUT... one of the fellows at work suggested that the constant bouncing as I travel would damage the winch...
What are your thoughts?
Old Aug 23, 2007 | 10:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Can't imagine what the problem would be with just using some simple tiedowns?????
Old Aug 23, 2007 | 08:00 PM
Red Rider
On the trailer, I would just install some anchors that will correspond to points on the quad where you can attach tiedowns. Most folks seem to use the four corners of the racks, but you do have to be carefull that the tiedowns won't rub the plastic somewhere. When I can't find any place else, I find that the footpegs usually make good points to hook tiedowns.
Just seems to me a lot of inconvenience to mess with the winch, when it takes just a few seconds to use a tiedown. It is also nice to have multiple tiedowns, so if one works loose you have several more to still hold the bike.
Old Aug 23, 2007 | 09:36 PM
BAIR's Avatar
OK, the WARN Rep has the last word;
"If you look at the first few pages of the manual you will see that it specifically notes not to use the winch as a tie-down.
This can shock load the winch damaging the end housing and other components.
The other main cause of a shock load is hooking the cable to another rig and then backing the quad up instead of winching them out. Basically using the winch as a tow strap."
So for all those folks out there that were using their Winch incorrectly... STOP IT!
Old Sep 5, 2007 | 11:11 PM
TimberedWolf250's Avatar
Very good to know,
I was going to buy a winch and use it like that on my trailer .
Friends have been doing that for yrs now.
I will tell them to stop, now if I come back all black and blue it was not from a ATV accident it would be from telling my friends to stop [img]i/expressions/face-icon-small-smile.gif[/img]
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
