CDI Question . . .
Old Nov 1, 2007 | 01:56 PM
S_Beaudry's Avatar
Default CDI Question . . .
I do not have any spark at all. I have replaced the battery with a brand new one and the engine cranks over easily and with the spark plug out, I do not see any spark across the gap grounding out.
Before I tear apart the wiring, I am checking all the componants and have come scross this.
Correct me if I am wrong here....the CDI has a 5 wire plug on it, I pulled it off and turned the ignition on and all 5 wires have 0 volts in them. As I crank her over, I find that the 2 wires from the magneto to the CDI become live with 0.12 volts. The wire from the CDI to the COIL also then carries that same 0.12 volts.
One of the 5 wires comes from the kill switch but does not have any power at all feeding the CDI box.
Sounds to me that maybe the magneto is bad, am I correct?
When I crank it over, what should the magneto be feeding the CDI box?
Thank you,
Steve
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
