Warn 2500lb winch wont work
I took my winch of for about 5 days because the cable kept snapping and i didnt have enough time to get a new one and i jsut got one today and i put it on and hooked up the wires and clicked the rocker button to reel in the cable and it only clicks now, does anyone know wats wrong
Maybe try warming it, my wifes would not work when cold on her outty but does fine when is warmed a bit. Should not do that but did. Mine works fine when cold as it what I use to plow with.
sometimes the rocker arms get moisture in it and you have to keep working the rocker arm until it makes contact. i have a superwinch rocker arm switch that does the same thing,,i need a new switch but until i get one all i do is keep playing with the button until it makes contact
That was my question. Do you hear the contactor click when you try to operate the winch? If not, it's bad. What did you remove - just the two winch wires, right? If you messed with the contactor wires, double check to make sure you reconnected them correctly. Good luck!
mines does the same thing,,all you hear is the contactor clicking,,i just just keep working mines back and forth ,,,back and forth ,,till it makes contact,,,than it works but kinda weak to me,,sometimes i think my winch is losing power doesnt sound like it reeling smooth,,have you had that problem,,
