Warn ATV lights
Old Mar 26, 2000 | 01:27 AM
TxDoc2's Avatar
Has anyone got the new Warn ATV lights? They supposed to be only 21 watts, but have a very efficient reflector and produce a lot of light for their size.
Old Mar 30, 2000 | 02:57 PM
BigCatDriver's Avatar
If they are anything like the 4X offraos light that Warn makes they are some awsome lights. One of my frat brothers had had a set on his jeep for 5 years with no problems whatsoever.
chuck
Old Apr 4, 2000 | 02:33 PM
BrianWSNC's Avatar
Doc.. did you get them?.. where did you get them and how much?
Old Apr 4, 2000 | 02:42 PM
TxDoc2's Avatar
I am about to order them. Don't know how mcu, but will post it and how they work. The reverse light is different from the front lights, I believe.
Old Apr 4, 2000 | 07:05 PM
TxDoc2's Avatar
The front lights are $69/pair and the rear light is $49 for a single. The front lights come with a handlebar-mounted switch and the rear can be wired to come on when revese is engaged.
Old Apr 4, 2000 | 08:25 PM
cowboy's Avatar
Who did you order them through? I'd like to put a set on my 'Cat for the front, then wire in a set on a switch that will come on in reverse, yet also be able to turn on whenever I want them on as well. Cabela's has a set of 55w H-3 Halogen lights for atv's, with mounting brackets and wiring harness for around $69 I think. Does anybody have any experience with those? Let me know what you think.
Mike
Old Apr 4, 2000 | 11:32 PM
TxDoc2's Avatar
I ordered them thru a local place that sells Warn winches and he beat the best price on my large winches and small ones. His supplier did not have any, so they are coming straight from Warn. The big deal to me is they are 21 watts, not 55 watts like the auto applications. So, they won't drain your battery. You can call Warn and get a specific brochure that gives the beam and light specifics.
Old Apr 9, 2000 | 09:36 PM
I just put a set of Warn 4X lights on my 2000 Cat, they are 55 watt but only pull 4 amps, thats what the box says. They are going to be wired through a relay so that they will draw their power from the battery when the hi-beams are on. I hooked them up temp. to see what they can do and they are awsome, but the 'Cat has a huge alternator to power them.
http://breifcase.yahoo.com/tkeiy593
Chuck
[green]2000 ArcticCat 500 4x4 ,Warn A2500, Warn 4X lights, and fully protected by 12" of ground clearance, and 27" BUGGS....[/green] [red]"Follow me and get the hell out of my way"[/red]
Up next a highlifter liftkit "I want two more inches, a diamondplate skidplate", Rino-coated racks, and a HL HorsepowerKit....
Old Apr 9, 2000 | 11:45 PM
TxDoc2's Avatar
Saw your pics. They look good on the AC!
Old Apr 10, 2000 | 01:32 PM
ecbaatz's Avatar
True but that is 4 amps per light
P=VxI
and actually it is 4.5833333
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
