High Octane Fuel - Where do you buy it?
Old May 5, 2000 | 09:57 PM
ScoobyDFW's Avatar
I was wondering where you get high octane fuel - higher than 93-94? How noticable a difference does it make? At the moment, I run a 9.7:1 compression ratio.
Old May 6, 2000 | 03:29 AM
Air's Avatar
Air
Go to a local track. Drag circle Atv whatever ask around some one will tell you of a good suplier.
I run 91 in an 11.5:1 engine at 4500 ft without any problems. You should be fine. Octane is how they measure a fuels resistance to detonation. The higher the octane the slower burning.
If you listen to every one the say it helps or it doesnt. It really shouldnt help "make power" unless you have a preignition problem then it will help this and make it appear to create power. In reality all it is doing is curing a compression or timing problem. Racers run high octane to stop detonation in their High compression engines. Not to make power
Old May 6, 2000 | 12:14 PM
Charles_Banshee's Avatar
Scobby
I believe there is a "store" over in Carrollton,Tx. that sell High Octane gas, it's on 35E on the service rd. next time I drive by I get the name. It use to have under ground pumps like a gas station but I guess they had to remove those. It's between Valwood & Beltline on the east side
Old May 6, 2000 | 12:21 PM
JohnR.'s Avatar
Like Air said it will not make any more power unless you have enough compression to require it. If you don't have high compression then you are just throwing away money.
JohnnySplat
Aug 6, 2015 12:07 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
