Yet another K&N filter question...
Old Aug 9, 2003 | 05:38 PM
quadturbo's Avatar
Default Yet another K&N filter question...
Originally posted by: WISTECH
One of the guys I ride with bought a 400ex new last year and installed a k&n right away. He is already complaining of oil usage and and a small amount of smoke. Next time we go I will do a compression test and check the intake tract. We have been riding severly dusty trails all summer .I mean trails so dusty you have to space each other out half a mile till the dust cloud settles so you can see. I used to use them a lot but I had several engines with prematurew wear. I have noticed on my factory foam filter it will look like hell on the out side but on the inside it is as clean and white as new. Again you guys should check out some of these web sites that are testing these things for air flow and filtering efficiancy. I still believe they would be ok for winter use or maybe in sand duning because the sand is large grain . But fine dust is another matter. Its your engine so a little research could be worth it.
you do have to clean k&n filters with the right stuff so it has oil on it. also get a outerware
Old Aug 9, 2003 | 05:42 PM
quadturbo's Avatar
Originally posted by: vampireforeman
just stating what my local dealer said to me.....they said their tech's could tell if i had been running a k&n...i don't see how either......is there a noticable difference when you add a k&n?
to u there is, but i dont see how the dealer could know. if ur using a stock filter ur engine wont brether as well, k&n lets more air in (clean) try sucking air through a piece of foam
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
