Race Gas and 440 kits?
Old Jul 1, 2000 | 04:23 PM
SNELL's Avatar
What do you have to do to get 44hp out of a 400ex motor?? I am going to be rebuilding mine soon and would like to know how to get that much hp. Thanks.
Old Jul 1, 2000 | 04:35 PM
SNELL's Avatar
Does Majic Racing sell JE pistons 88mm, race cams, springs, etc because I will be taking my 400ex to the shop to get torn down and I would like to know if I can get the parts from Majic Racing?
Old Jul 2, 2000 | 03:41 AM
Trx440's Avatar
Call GT Thunder in Ohio or TC Racing in PA. If you like westcoast guys call CT Racing in CA or Curtis Sparks Racing [also in CA.] They will tell you how much it's gonna run you. Plan on spending upwards of $2000 for the engine work. 45hp is at the upper limits of the 400's capabilities. It takes some coaxing to get that much out. That $2000 is just the beginning however. If you've got that much juice you'll need a wider and longer quad, better shocks and all the aftermarket extras that will make your quad complete. Good luck and listen to what the tuners have to say. Let us know how it goes. -RT
Old Jul 2, 2000 | 11:38 AM
Trx-400ex's Avatar
Slyder what did you do to yours? And how much did it end up costing you? I was planing on building my own also. And just wonder what price range I am in.
Old Jul 2, 2000 | 04:23 PM
  #15
SNELL's Avatar
I've already have Denton +2 A-arms, stainless steel brake lines, Nac's 145/80/10 grooved radials, FMF 909 bars, Works triple rate w/cans, RPM +4 axle, grooved 18-11-8 turf tamers on douglas .190's, k&n filter, 152 main jet, PEP steering damper, AC nerfs, bumper, etc. I'm just looking right now for some mods to do since my quad needs new rings. I figure while I have it apart I might as well upgrade a little. Thanks for the info!!!
Old Jul 3, 2000 | 12:35 PM
  #16
Johnnnn__H's Avatar
MotoMatt and Backcountry have the facts, You want to runn the least amount of octane that will let your motor run properly. Anny more and you will lose HP and money.
Old Jul 5, 2000 | 05:14 PM
  #17
Slyder's Avatar
I have the 440 kit (Wiseco piston) with 11:1 compression, the Webcam midrange cam, plus all the normal bolt-ons (pipe, filter, jet kit). As far as the internal engine mods go, here are the prices I experienced. Cam: $150 plus shipping (there is a $170 core charge which they will refund upon receiving your original cam in good condition). Big bore kit: $206 (includes shipping). This includes the piston, rings, 89mm sleeve, and gaskets all ordered directly from Wiseco. Labor: $15 to change camshaft gear mounting flange. $75 to remove old sleeve from cylinder, install the new sleeve, bore and hone new sleeve to match new piston.
Add it up, and my total for the internal engine mods is $446 plus whatever shipping I paid on the cam (probably 8 bucks).
Old Jul 6, 2000 | 01:12 AM
  #18
Trx440's Avatar
Slyder,
You did the work yourself and it cost you $450. What about the header/silencer? [@$400] What about the Rev box? [$110] What about the K&N filter? [$40] I will assume you've got the proper main/pilot already. $450+$400+$110+$40=$1000. If you are gonna do a big bore [by yourself] this is the bottom line. Why would you do the engine work and not finish the package? Maybe you are still running the stock exhaust,filter and black box. Somehow, I doubt you are.
Old Jul 6, 2000 | 01:23 PM
  #19
Slyder's Avatar
Read my post again. I stated in there that the $450 was for the internal mods only. I am assuming (as you have) that anyone interested in a 440 kit has probably already installed a pipe and filter. I do currently have a pipe (E-series) and K&N filter on my bike. I only paid $175 for my E-series (silencer only) and it is just as fast as my buddie's bike with the same internal engine mods and a complete Big Gun system.
My main point with my post is this: These outfits sell 440 "kits" for anywhere from $285 to $350. These so called "kits" are usually just the piston, sleeve, and gaskets. You can get these same parts yourself by ordering them through the manufacturer (Wiseco, JE) and save a bunch of money. From Wiseco, it will cost you $200 plus shipping. Install the kit yourself (it ain't that hard!) and save even more!
Robinhood
Dec 26, 2015 10:28 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
