What pipe should I get for my Z 400 I have some ideas.
I am thinking about a pro circuit
yoshi
fmf.
Also if I start out with a can only could I add the header pipe later? thanks.
I don't want somthing to loud. Does anyone have any sound clips?
Also where is the cheapest place to get a system.
yoshi
fmf.
Well since you don't want something too loud, I would highly recommend getting the Yoshi and then buying the TEC inserts they sell for about $30. It comes with 2 inserts, a medium size and small size baffles that restrict the air flow, and greatly reduce the sound. The reason I say to get these is that you have your quiet insert for local and trail rides, and then just leave those inserts at home when you head to the dunes for max power.
you should really look up tha dirt wheels exhaust shoot out. it has hp, weight, loudness, powerband and its very informative. it said that pro circuit and ct had the highest hp gains but ct weights in the most at 8lbs 3 lbs lighter than stock but the yosh weights in at 4lbs. i think im going to get the pro circuit cause its slightly louder and weights in less than ct and has a good gain. just my .02
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
