trick racing turbo banshee kit
Old Jan 28, 2004 | 07:33 PM
cRazyJ's Avatar
Default trick racing turbo banshee kit
does any one have this kit? look at trickracing1.com im thinking about splitting the cost of this with a friend of mine.
Old Jan 31, 2004 | 12:13 AM
Doctorturbo's Avatar
GOT BOOST!
Looks like a nice kit from the picts.
Old Jan 31, 2004 | 03:22 PM
Daren420's Avatar
I'd check out A&S racing (bansheeracing.com) Dan Hull makes some fast Banshees. He also has some videos of his turbo Banshees.
Old Feb 19, 2004 | 03:09 PM
ThreeWRacer's Avatar
how the heck do yu get boost from a 2 stoke.
Old Mar 3, 2004 | 10:34 PM
havinnoj's Avatar
The name "Trick" should tell you something about their products.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Mar 4, 2004 | 07:45 PM
Bubba297's Avatar
If the engine makes exhaust, then it will make boost through a turbo. The exhaust spins the turbo and that forces air into the intake manifold in plain terms. That's where the boost comes from.
Old Mar 5, 2004 | 05:36 AM
DaBeechMan's Avatar
5G for a used turbo? LOL you bumped your head!
Old Mar 5, 2004 | 12:40 PM
I know how a turbo works i just never thought you could get enough pressure from a 2 stroke.
Old Mar 5, 2004 | 10:25 PM
GOT BOOST!
ThreeWRacer, your right, and they really don't have much boost pressure in the cylinder. Unlike a two stroke, a four stroke,when the valve pops open, the cylinder see's the same PSI as the intake manifold. (This is not really true because the piston is dropping away and this drops the presssure.) This can't happen in a two stroke because there is a big hole called a exhaust port that lets the pressure out. The only thing that keeps the pressure in a typical two stroke cylinder is the turbin wheel back-pressure, and that ain't much. It will blow down the cylinder and make a real good, very uncontaminated intake charge, unlike a typical two stroke charge. That is where the power increase comes from.
Old Mar 5, 2004 | 10:33 PM
cRazyJ's Avatar
you summed it up pretty damn good, you wouldnt beleive how long it took me to peice that together in the net 8yrs ago when i tried to figure out why 4 strokes had more back pressure, took me like an hour
ReconBayou
Oct 31, 2022 05:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Logan Collins
Sep 5, 2015 08:03 PM
