performance expectation for a 4mm stroker banshee
i have a 99 banshee. i currently have fmf fatty pipes with powercore 2 silencers, vertex pistons, pro flow intake, and k and n filters. it has been jetted accordingly and now i think i want a bit more torque, what kind of performance can i expect from a 4mm stroker kit? will i need a spacer plate? also where should i go to get lectron carbs on the net? thanks
The only thing I can tell you to expect is FAST!!!! My brother took the advice of Ernie660r. He had a 99 Shee, with Toomey T-5's, boost bottle, jetting, K+n, and a +8 swingarm. He added the 4mm crank that Ernie sugguested, also added high compression pistons, wicked intake, Fcr carbs, 18cc head, port and polish work and cams. This package is very impressive. It can flat out fly.
Plans for more, bore and alcohol.
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
4mm, adjustment, advice, banshee, carb, compression, fast, intake, job, kit, performance, port, strocker, stroker, wicked
