400ex-440ex
Old Mar 21, 2004 | 09:55 AM
exkicksazz's Avatar
Default 400ex-440ex
I have my 400ex in the shop getting a wiesco 440 kit installed.I am getting 12.5-1 piston,
hrc stage two Cam.Can i run pump gas or should I add octane booster?
My other mods are fmf hi flo header,fmf power core 4 muffler,k&n air filter,dyno jet kit .Also should I use synthetic oil? Any other suggestions welcome.
Thanks, ex kicks azz
Old Mar 21, 2004 | 12:19 PM
madracing's Avatar
Default 400ex-440ex
your builder should know. i just finished a 426ex and it runs on race gas, it gets a little better throttle response
Old Mar 23, 2004 | 10:13 PM
emac's Avatar
Default 400ex-440ex
yup, u will need race gas, anything over about 11.1:1 in a 400ex will need pump gas i think
Old Mar 24, 2004 | 12:44 AM
Quadkrazy400ex's Avatar
Default 400ex-440ex
race fuel is reccomended and supposed to be run in anything over 11:1 compression. the above post was written backwords.
in the same idea, anything below 11:1 can be run on like 91 octane.
Old Mar 24, 2004 | 06:43 PM
emac's Avatar
Default 400ex-440ex
o ya sory about that, didnt catch it the first time
Old Mar 25, 2004 | 08:35 AM
drift440's Avatar
Default 400ex-440ex
I've never had a problem with running pump gas (91 octane +) in my 440. It also has the stage 2 cam, edlbrock quicksilver carb, k&n filter and LRD exhaust. You could put a little pump gas in and see how it runs, if the power is there and you hear no pre-det your all good. If it runs bad add the good stuff.
Old Mar 28, 2004 | 11:16 AM
SANDMAN430's Avatar
Default 400ex-440ex
you could mix half and half.
