Raptor clutch Question
Old May 1, 2004 | 04:16 PM
Jam2187's Avatar
Default Raptor clutch Question
I'm installing new clutch plates for my 2001 raptorand i was wondering where exactly the black c-ring goes in the middle of the clutch plates. Thanks for your help
Old May 2, 2004 | 10:28 AM
Ward660R's Avatar
Your clutch plates (fibers that is) go in a specific order. You should have two fibers that have a different inside diameter than the rest, this is key. Starting from the clutch basket side put a regular fiber/steel/reg. fiber/steel/odd size fiber/ THEn the peice your talking about (also called a spring/steel/ finish out rotating regular sized fibers and steel plates. The last oddball one goes against the pressure plate. It honestly doesn't exactley matter where it goes, as long as it is on the inside of one of the odd sized fibers and between two steel plates somewhere in the middle of the clutch pack.
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
brad wheeler
Jul 13, 2015 11:19 PM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
