ATC350R
Someone with an air cooled ATC250R might be interested to know that an FL350R cylinder has the same base bolt pattern. It is a 68mm vs 64.4mm stroke. That is not much to have an engine stroked or the cylinder could be machined on top and bottom to retain the shorter stroke.
The intake is also the same mounting. I am using a TRX250R V-Force cage in mine.
