Help with Raptor hot cam
Old Sep 10, 2004 | 04:30 AM
727raptor's Avatar
Default Help with Raptor hot cam
Can anyone give me some info on installing A new Hot Cam in A 660 Raptor. Do you have to make any other changes i.e. Motor , Jets , ...........
Thanks for any help.
Old Sep 12, 2004 | 06:18 PM
adambomb04's Avatar
oil change after you ride it, like ride it for like 10 hours and then change the oil and there will be some jetting need to be done
Old Oct 5, 2004 | 03:15 PM
Raptor4stroker's Avatar
It just depends on what cam you are putting in your bike. Hot cam stage 1 is just bolt in and go. You don't have to have the 11:1 piston but it would help. If your looking for some serious gain in your top end then the stage 2 is the way to go but you will need a new piston and buy the spring kit also. Then the little secert that no one tells you with the higher lift cams is you need to get your rockers hard welded and heat treated. Yeah this sounds like a lot but my 02 raptor is putting out 62 hp on the dyno at the rear wheel. As far as jetting went I did not have to change my jetting when I put the cam in as well as port and polish. What kind of pipe are you running and is it with a dyno jet kit?
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
