will a blaster top end fit and run on any other yamaha bottom end
Old Sep 16, 2004 | 08:44 PM
fordblaster's Avatar
Default will a blaster top end fit and run on any other yamaha bottom end
a balancer gear broke in half and lodged itself between the crank gear and cracked the casing.
Old Sep 16, 2004 | 08:54 PM
ThreeWRacer's Avatar
ouch
Old Sep 18, 2004 | 06:26 PM
Shav0's Avatar
The blaster is the same motor as the Yamah IT200. I think they stoped making it in the late 80's or early 90's, but thats where the blaster motor came from.
Old Sep 18, 2004 | 09:36 PM
did those have manual clutches
Old Sep 19, 2004 | 12:53 PM
  #15
Raptoryfn660r's Avatar
RIP Dear Friend
I think they made them as late as 1997, for the money not a bad machine and yes they were manual clutch.
Old Sep 19, 2004 | 03:46 PM
  #16
cool maybe i will lok for one of those to and see if i can get it cheaper or something. how positive are you that it will bolt straight on to an 87 blaster's top end. thanks for the help
Old Sep 19, 2004 | 04:33 PM
  #17
RIP Dear Friend
OOPs my bad, Shav0 was correct and I was thinking of the Yamaha RT180 which ended in 1998.
The last IT being the 1985 IT200.
Old Sep 21, 2004 | 07:54 AM
  #18
Shav0's Avatar
Fordblaster.
Im positive it will fit, it's the exact same motor. When yamaha was first desiging the blaster they didn't create a new motor, they simpily took one from another bike they had and built the blaster around that. To look at a IT motor sitting next to a blaster motor you won't tell the difference.
Old Sep 21, 2004 | 10:41 AM
  #19
potentpete's Avatar
the it200 does not have a counter balance gear, the cylinder will fit, but good luck finding an it200 engine, your better off just buying a couple used case halves and rebuilding the bottom end, it will be cheaper and more reliable in the long run, trying to rig another bottom end that was not supposed to be will just be major frustration, besides, what you'll pay for a bottom end, you could pick up a couple case halves for about 100.00 on e-bay, you won't find a complete bottom end for that, and then to find a bottom end that doesn't need rebuilt is going to be rare also, think about it, the blaster bottom end has way more parts available than the it200.
Old Sep 21, 2004 | 02:56 PM
  #20
Shav0's Avatar
You can use the bottom end without the counter balancer gear if you true the crank. If not it'll vibrate and cause problems, but like pete said, you might be better off to just get genuine blaster stuff.
merryman
Jan 19, 2016 04:29 AM
scott1988
Aug 18, 2015 08:44 AM
Polarisman1123
Aug 13, 2015 08:13 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
