vitos key
Old Sep 19, 2000 | 03:14 PM
BANMAN's Avatar
Has anyone used one of vitos ignition advance keys yet. If so did you get any results? I guess they advance the timing 4 degrees.
Will they cause preignition if i just use pump "92" gas?
Old Sep 19, 2000 | 04:29 PM
HILLSVILLE69's Avatar
im running one on my blaster with there Superstock Piston package on 92 and it seems to be alright.
Old Sep 19, 2000 | 09:19 PM
H300F's Avatar
yeah i was also wondering about them, and is there a way you can change your timing without buying something like this?
Old Sep 19, 2000 | 11:02 PM
MADPOWER's Avatar
I purchased one 2 sat. ago...put it on tightened it up..and well it sounded great for a sec..then died...sheared the somebisatch right in half.. So long story short..I reopened her up and put the original back in..I thought it sheared because the fly wasnt tight but...I tightened the same way..49 pds as per book..and the stock one is still in 1 piece..So to answer your ?? I have no clue...I recalled Vito and left a message and left my # and had no response...??Dont know guess i'll have to recall and see if he'll will warrenty the key...GoodLuck tho it does sound like a good idea...If it wouldnt shear.. Madpower
97 Banshee ...To many mods..
Old Sep 19, 2000 | 11:42 PM
slickster's Avatar
Heh,
Get the Adjustable Stator plate from HyTech ATV. Its identical to Pro Design and Trinity and it retails for $69.99. No risk of shearing and you can adjust your timing from -10 to +10 degrees.
I have one. Works great. I run +5 with Pro Design Cool heads at 19 cc domes, 108 octane VP C12, Toomey pipes,etc.. etc... etc...
Really too much to get into.
Slick
Old Sep 20, 2000 | 06:48 AM
fish_bulb's Avatar
The key is just for centering. The stock, nor Vitos will take much torque at all. The tapered crank is what keeps magnitos in place.
Old Sep 20, 2000 | 06:09 PM
H300F's Avatar
That stator plate from hy-tech racing for $70. Is that the only part you need for it to work or are there other parts you must also buy?And how hard/easy is it to put on and what about adjusting the timing hard/easy??
And what is the most advanced I can go and still run on 93 octane without any problems?
Thanks
Old Sep 20, 2000 | 08:32 PM
Did this break o your Banshee or blaster?
Banman what are u wanting to use it on.
Old Sep 21, 2000 | 03:45 PM
BANMAN's Avatar
I have a 98 Banshee. This will be my second time trying the key. My first one got all messed up (i thought i dident get it in the correct way but now i am wondering if it dident also shear off)????
I already ordered another so i guess i will try again.
Has any one else had a key shear??
maybe i should call vito..??
Old Sep 23, 2000 | 05:23 PM
free1steven's Avatar
The torque of the Magneto is 58ft.lb not 49. That could be your problem.
