fuel injection sport quad???????????
Your so right about people screwing up the jetting. The altitude and temp adaptation features are sweet to. A couple weeks ago I was tried out 3 maps and a dozen fuel settings in about a half hour. It was a modded engine with a different exhaust. Man back in the old days Id have wasted one or 2 days at least getting a carb setup correctly. Cant beat plug and go. The diagnostic features are just like cars to.
One drawback to efi is that it is easily damaged by those who dont want to learn how to work on them correctly.
By the way the GasGas450 is also a fuel injected race quad.
Most, (actually none unless the GG has one I dont know about), of the current EFI quads availible in the US market have an O2 sensor. So instead of jetting with your carbs, you'll be mapping fuel with your computer. Either way its not a plug and go situation, but KMS is supposedly in the works on just such a setup.
PLUG in your laptop change the settings /map to your preferance and GO. The Optimum system was originally designed with and 02 sensor (in fact the wires are still in the harness) but it was not used. Its a less complicated system that way. The 02 sensor is handy for keeping track of the lean/rich conditions but since there is software out now to edit our own maps it would add even more parameters to mess with for the do it yourself map builder. The fuel and timing tables are enough to deal with already. There are several maps out there that can make a stock engine put out incredable power but I know they will shorten engine life big time. Which is why I recomend sticking with factory maps or custom ones using blends of one or more stock maps.
#15
#16
The only thing that truley sticks about EFI is if your battery is dead, your screwed!!! no pull starting the quad to get back to camp
#17
Originally posted by: moldycheese
you can still pull start a quad with efi. the battery doesnt supply the engine with the current to run the efi. that is done with the alternator. so as long as the alternator (or stator i guess in a quad). as long as the stator is spining it is creating the electricity to run the efi
interesting.....
I was thinking that with a dead battery your Fuel pump wouldnt work, thus no gas to start. Are you saying the stator will turn over fast enough to supply enough current to the fuel pump when being pull started??? I didnt think that was possible, but I hope you are correct, cause I am putting a EFI motor in my DS,and that would be good news[img]i/expressions/face-icon-small-smile.gif[/img]
bigger.
#20
Originally posted by: BillWoods
With a Megasquirt Fuel Injection controller and some salvage parts, you can fuel inject any quad. Build it yourself controller, very inexpensive.
Google up MegaSquirt
This setup rocks!
This setup rocks!
