Yamaha R1 ATV
Old Jul 28, 2005 | 08:17 PM
RandyH's Avatar
Default Yamaha R1 ATV
I have a 2003 Yamaha Raptor and just bought a 2005 Yamaha R1 1000 cc FI engine. Has anyone used this engine in a ATV frame. I am thinking about putting it in my Raptor frame. Any ideas?
Old Aug 19, 2005 | 02:22 AM
speedi's Avatar
I hope your building this thing for the dunes. The only other place i can see you using it is a littleplace called Pikes Peak.
Old Aug 19, 2005 | 03:45 PM
Boombotz's Avatar
THAT IS SOME SICK SH*T OMFG IF U DO THAT U WOULD KILL....THATS A NASTY IDEA BUT I THINK YOU WOULD NEED 2 GET THE FRAME MODDED AND PUT THE ENGINE ON ITS SIDE OF SOMETHING 2 FIT IM NOT SURE IF IT WOULD FIT A STOCK FRAME
Old Aug 21, 2005 | 03:40 PM
420rappy's Avatar
that would be crazy fast and if you had the tools and know how you could do it DO IT..............
Old Sep 1, 2005 | 12:22 PM
sandkraut's Avatar
I have installed a FJ 1328 4 cylinder in a raptor frame and it went in real easy. The R1 engine is a little smaller than the FJ so you should have an easier time of it. You have to move the engine as far forward as you can and spread the down frame tubes a little for exhaust clearance for the two center ports. This also gives you the necessary clearance for the f.i. , or carbs in my case. The actual engine mounts are a little tricky but are easily fabricated if you have experience. Cut the horizontal tube just in front of the foot peg and at the front of the tube where the lower front engine mount is. This is where the tricky part starts, custom fabrication of all the motor mounts. Hope this helps and good luck.
Old Feb 7, 2007 | 06:52 PM
SickSixtyRider's Avatar
I saw pictures of a rappy that a guy put R1 motor in. It was on this forum but I can't remember his user name. It almost looked stock, except for the sweet looking duals out the back and the speedo and tach on the handlebars. Just make sure u beef up the drivetrain.
Old Feb 8, 2007 | 03:50 PM
bluedemon's Avatar
i ve seen it done but you better build it right and have a big wallet. cause my friend had one and everytime we raced he was breakin something...
chains
sprockets
u name it he broke it (he also had n.o.s. on it and a turbo also)
Old Feb 8, 2007 | 09:26 PM
BBR650's Avatar
Is always changing bikes.
http://s129.photobucket.com/albums/p...YFZR-1idle.flv
the fog's yfz r1 at st. joe state park.
Old Feb 11, 2007 | 05:01 PM
3ismorethan4's Avatar
do you do 300ft dirt drag's ??
Old Feb 12, 2007 | 02:04 AM
BBR650's Avatar
who?
