Banshee thermostat?
Old Nov 6, 2000 | 12:58 PM
fish_bulb's Avatar
I don't think it's all that rare. I believe the newer Banshees run hot. In our group, we've got 6 Banshees ('91, '92, '97, '99, and 2-'00's). The 2 older ones run a constant 180. The '99 and '00's hit 250 while cruising. Very odd. (We just installed the temp gauge on the '97, so I'm not sure what it runs yet).
Old Nov 6, 2000 | 06:06 PM
RoostKing's Avatar
Im not sure how it is the newer banshees are running hotter than the older ones, they are exactly the same. Im not doubting your experiences, but it just seems odd. At any reate, I dont overheat often, just when I run it Hard...
RoostKing...
Old Nov 6, 2000 | 09:34 PM
H300F's Avatar
I read on someone's website that it is just the location of the resevoir bottle(container) and he mounted his by his front bumper and it never flowed over again??
I have a 95 and if i am playing around in an area hard on it, it will flow over, which is probably normal, but if im going along moving fast along trails it never does.
just shut it off when it over heats. and when stopped and idled shut it off because they build up alot of heat when stopped because no air circulation is hitting the radiator, that is why when moving along they dont get hot, air is flowing through the radiator keeping it cool.
it could also be your i forget what its called i think a impellar? in the water pump that keeps your fluid moving through the engine, stock ones i am pretty sure are plastic and sometimes melt, if it melts it is useless, pro design sells a alum.? one which wont melt and will fix your problem if your stock one is ruined/melted.
Kaleb_00
Jun 1, 2016 09:15 AM
400H0
10
Aug 20, 2015 07:34 PM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
