A LITTLE HELP HERE
Old Nov 6, 2000 | 07:20 PM
rawze's Avatar
HOW'S THIS SOUND-ANYONE SEE A PROBLEM. 96 BANSHEE 30 OVER NEW WISECO CRANK AND PISTONS, DG EXHAUST, TOOMEY 2:1 FILTER, BOOST BOTTLE, 12 TOOTH SPROCKET FRONT 41 BACK(3.42 GEARING), 280 JETS. YAMALUBE 32:1. WHEN I FIND A GOOD HEAD TO REPLACE MINE THAT IS SCREWED UP ON ONE SIDE, I'M THINKING OF GETTING IT SHAVED .045 - WOULD I NEED TO CHANGE JETS IN DOING THIS
Old Nov 6, 2000 | 11:14 PM
PHATTYBOY's Avatar
HHHHUUUUUMMMM......
Old Nov 7, 2000 | 12:14 AM
brokemybanshee's Avatar
Geez.. sounds like its a time bomb... better store it in my garage ;-)
Old Nov 7, 2000 | 01:46 AM
1BEARMAN's Avatar
I wouldnt use the DG pipe,the pipe almost hits the petcock and rattles a lot.You cant beat the toomey pipes and jet kit.Trinity can usualy save trashed heads and perform a rechamber and turbo pattern.hope this helps
Bearman
Old Nov 7, 2000 | 09:39 AM
sAyIt_fmf's Avatar
Sounds like a good match up.....
I'm not sure I would go with a 12 tooth up front...but thats just me....stock is 14. 13 is what I'm running on the same year banshee with just about the same mods.
Old Nov 7, 2000 | 02:05 PM
sik_banshee's Avatar
Start with 320 mains and 30 pilots if you are at sea-level. 280s at sea-level will be lean.
Old Nov 8, 2000 | 04:39 AM
PHATTYBOY's Avatar
IF YOU DO GET THE HEAD CUT...YOU MAY NEED TO RE-JETT IT LEANER 1 MAIN JET SIZE...FOR ADDED COMPRESSION.
