250R 38 AIR STRIKER VS. 39 PWK
Old Nov 6, 2000 | 11:56 PM
PHATTYBOY's Avatar
OK THIS IS IT 250R 86 PAUL TURNER PIPE/DELTA V-FORCE REEDS/PORTED/POLISHED/.30 OVER......
WHICH IS BETTER 38 AIR STRIKER OR 39 PWK ?????
LETS HERE IT!!!
Old Nov 7, 2000 | 09:54 AM
Backcountry's Avatar
My vote would be for the 38 A/S, the throttle response is better than a plain PWK. 39mm's is in some peoples opinion a tad large for a plain 250.
Old Nov 7, 2000 | 10:34 AM
todd330r1's Avatar
I think it matters what your using the bike for, if your running mx then the 38 a/s is the carb, but if your drag racing flat out in 6th gear, the 39 pwk will give you just a little more. I have a 38 a/s on my 250 and a 39 pwk on my ct350
Old Nov 7, 2000 | 12:32 PM
Lasher's Avatar
I have the 38 AS on my 250r. I absolutely love the carb. As far as how much difference it makes, I am not sure. The motor was rebuilt (v-force reeds added) all at the same time. But the trottle response is great and I am very happy with the carb.
Both, K&K and REP (motor guy) suggest the 38 AS is the best right now for MX on the 250R.
Of course, my motor guy told me about a brand new carb, forgot the name, for the 250r that is supposed to add about 5 more hp upon bolt on. I think the cost is about $500. But here is the kicker! You do not have to change jets! There is a screw on the top of the carb that some how changes the jetting. The thing look awesome, but for the extra money, I decided to pass.
Old Nov 7, 2000 | 02:55 PM
I think you're talkig about the PSI Performance "Big Air" carbs, they have a website www.psiperformance.com
Old Nov 7, 2000 | 06:43 PM
PHATTYBOY's Avatar
THANKS GUYS ....I ORDERED THE 38 AIR STRIKER TODAY
...I ALSO THINK IT SHOULD WORK WELL!!! IM GETTING
MY MOTOR WORK DONE SO WHEN IT RUNS ILL LET YOU KNOW....
Old Nov 8, 2000 | 01:44 PM
Yeep's Avatar
My 250r has stock carb, and it pulls really hard. I has some much bottom end and top end that it keeps up with modified banshees. The Only things that I have on my quad are FMF pipe and silencer, the reeds are still stock, and I put in a (thin) high compression head gasket. I think the piston is still stock.
I ride on really soft terrain (grable).
Now I want to get some more power. I think I am goint to get the cylinder ported and Vforce reeds. Maybe I will consider the air stryker later, oh by the way how much is it?
Well peace you all.
Old Nov 8, 2000 | 10:17 PM
jeepin's Avatar
MY 250r still has the stock carb and I beat a ct310 and a paul turner 330r to the first corner.My bike pulls extremly hard.My freind rode it hit the power ban in third and couldn't reach up to grab the clutch.It is fast and handles awesome.LONG LIVE THE R!!!!!!It was funny because the guy sitting next to me at the gate was bragging about how fast his ct310 was.Until he was eating my dust.
86 trx250r wiseco .020 piston,boyesen reeds,porting by p.m.s,FMF fatty gold series pipe,power core 2 silencer,dg alloy series nerfs,JD performance +2 A-arms,LSR carrier,durablue eliminator axle,duablue posi loc axle nut,fastline braided steel brake lines,braking brake pads,uni filter,152 main jet,nac's casesaver,PEP easy pull clutch perch,white bro's white power shocks with adjustable res's all the way around,pro design kill switch,motion pro clutch cable,18/11/8 holeshot mx's on mitchell .190 wheels,21/7/10 holeshot's on ITP wide off-set .190's.
www.angelfire.com/me3/fmf86trx250r
Old Nov 10, 2000 | 03:40 PM
PHATTYBOY's Avatar
JUST SO YOU KNOW.....I HAD TO REPLACE STOCK THROTTLE CABLE....AFTER RESEARCH,USE AN 85 ATC
THROTTLE CABLE,THIS WORKS GOOD!!(FOR THUMB THROTTLE)
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
