460 YFZ
Hey yall, Im thinking of adding this to my YFZ.....First Question-Is this a good package(Quility Parts)? Second-Is this to expensive for what im getting or could i find better parts for less? And if any of you have bought this tell me how it works for you? I already have the X-6 exhaust and Performance Jet Kit....so idk. I really want to upgrade my quad for this summer!
Sparks Racing piston kit 97mm 13:1 by JE Piston BPKY04450YFZ97 $209.95
Sparks Racing bore & re-plate cylinder Labor-Platecyl $250.00
Sparks Racing head gasket 97mm CHGY004450YFZ96 $39.95
Yamaha base gasket 5TA-11351-00-00 $7.52
Sparks Racing camshaft set (In development) CAMY04450YFZ
Sparks Racing X-6 exhaust system PY04450YFZ $459.95
Sparks Racing performance jet kit PJKY04450YFZ $38.95
Sparks Racing Air Super Charger kit AFKY04450YFZ $119.95
Sparks oiling modification (requires complete motor tear down & assembly) Labor-oiling mod $50
Complete motor tear down & assembly Labor-tear down & assembly $399
Sparks - Dyna CDI system CDIY04450YFZ $419.95
just a forewarning, curtis is generally a couple months wait for engine work. the dyna can be found cheaper and just have the cam mod done instead of getting new cams. they should be able to get it done much sooner if you want just the cylinder done, just put it together yourself.
he did not have enough time for my deadline to put together the entire engine so i sent him the cylinder and head and put the engine together myself. i know the trx/crf engine's better than i know any other engine so i was not an issue.
