raptor 660r carbs
I see that you grenated the engine twice, its more than likely the reason this happed is because of the stock carbs and running the quad at high speed for long periods of time. Doing this will cause a lean condition because the stock carbs can hardly feed the stock engine with what it comes with.
I would forget about the Elbr. single carb and go with dual 35mm or 39mm FCR's. These carbs kick but...... You can find them used for about $500.
Hey Cody, Please tell me more about your Eddy carb set-up. Everybody bitches and says it's hard to set up.... Well, what do you think? I haven't broken in my engine yet... Clutch couldn't handle the new power load. Wondering if I should re-carb first.... Thanks, Chris
#15
P.s. Cody..
If you can, drop me a line at my E-Mail Account... flyloops@sbcglobal.net That goes for anybody else who reads this and has a viable solution to this.
