ATV help
Old Mar 10, 2006 | 07:37 PM
icex48x's Avatar
Default ATV help
Hi. i have a eton 90 viper.. when i start it up and give it some gas it dies on me? at first i could barly press the gas and it would go very slow.. then if i tried to speed up or floor it it would die instantly first thing i figured was the throtle was turned up to high? but im clueless on this stuff if anyone has any ideas how to help me plz do...
and hope this is the right place to post if not sorry [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 10, 2006 | 07:42 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Default ATV help
Yuh you might want to move it here so people that can help you will see it.
Click Here
Old Mar 10, 2006 | 07:45 PM
icex48x's Avatar
Default ATV help
Ok thanks and sorry bout that..
Old Mar 10, 2006 | 08:01 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
Veteran: Army
Loved
Community Favorite
Default ATV help
No need to apoligize, Good luck getting it fixed. =]
Old May 13, 2006 | 07:26 PM
ghostbuster's Avatar
Default ATV help
the fuel may be old and varnished, drain the fuel and top off with fresh fuel, its the cheapest and easiest way
to determine if this is the problem before taking expensive measures.
Old May 17, 2006 | 03:30 PM
gassrx's Avatar
Default ATV help
good answer but if not it is rich and if you go to my url at bottom there is jetting page or call me at 402 270 1768
Old May 18, 2006 | 07:50 PM
fixitman69's Avatar
Default ATV help
Gassrx is good when it comes to fuel problems, but I don't think that is your problem here. Most of your off breed atv's are coppied after the big name brands. I have seen quite a few that have a safety switch on the throttle lever that is coppied after the banshee. They are designed so that if your throttle sticks open and you let of the throttle lever, the lever hits the switch and kills the ignition. I think this is why it dies on you when you push on the throttle. Check the switch inside the throttle mechanism on the handlebars, and also the wiring going to it. Most of them have a small electrical box that looks similar to a relay that controls this and sends the signal to your cdi box. Don't overlook any of these components.
Old May 20, 2006 | 01:02 PM
fixitman69's Avatar
Default ATV help
Any luck with it ice? Let us know how things are going with it.
