Best 4 stroke pipe
I've run a DG RCM pipe on my 300EX for the past 3 years. With the right mods to compliment it...I gained substantial mid to high range power increase. And yes, it is pretty loud..but it hasn't fallen apart yet and I don't expect it will. If I had to do it all over again, I would probably spend the extra money and go with a quieter exhaust system like the FMF e.a.r. series.
ok i am stuck between an white brothers e-searies s bend or a supertrapp ids2
the ids2 is around 300 compete kit
the e-searies is around 250 silencer only.
would the ids2 be better since it is the whole kit?
I'm not familiar with the Mojave head pipe but in my opinion, you need to go with the larger of the two...factory or aftermarket. Without a larger headpipe you're not gonna increase the air flow through the engine much. I'd recommend an aftermarket air filter like a K&N also...of course with all this incresed air flow, you'll need to rejet to get more gas in or you'll run lean. One without the others is not gonna help you much...and could even make your quad perform worse.
I have a 2001 mojave, ordered the supertrapp IDS2, went to put it on, headpipe fit, muffler fit, but couldnt get intermediate expansion chamber to fit. When I called supertrapp I was told "the jig probably slipped" They wanted me to pay to ship the whole exhaust(AT MY EXPENSE) back to them so they could figure out their mistake. After spending $300 I felt they should stand behind their product. I returned the exhaust. I looked at the white bros pipe, didnt like the 'fake' non functional exhaust tip, which only is functional if you run it straight open. I didnt like WB exhaust which would soot up plastic unless you buy "exhaust heat shields" for an additional cost.
