1996 4x4 scambler 2wd conversation help.
Old Jan 6, 2007 | 03:18 AM
DREWBOB's Avatar
Default 1996 4x4 scambler 2wd conversation help.
I have a 1996 4x4 2 stroke 400 scrambler with a ton of work done to it. By far i have seen the big boys that are in the forum, and by far m noy one of them. However i have had motor work down by AAEN. It has a 470 big bore kit. ported, quadzilla modified reed intake, which has been ported. vforce reed valves, AAEN Billet haed, 44mm flatside carb. Directflow K/N. Cluch kit, 2 INCH AAEN Extended Swing arm, with a double rated Ohlins nitro Shock. In the front i have AAEN plus 2 plus 1 extended A-arms, with dual gas shocks, as well as the stock struts....on top of that a steaering stablizer. oil block off, pipe BLAH BLAH BLAH
My question is this. as you know, 1995 1996 4x4 has 3 seperate chains to drive the rear wheel, the rear braks and the front hubs, while in 4x4. I want to completly ditch the 4x4, front half shalfs, barrier carrier, chains....etc.
obviously, the rear chan with operated threar wheels and the rear breaks. Taking off the front half shaft chain and shafts screw up my spendel?
Is the anyone that can help me , that might have done this before?
thanks for your time.... : )
BentDoG
Old Jan 9, 2007 | 02:10 PM
Whitedog's Avatar
It wont be a problem. Just pull the shafts out of the cv joints. And remove all the rest
Old Jan 9, 2007 | 03:20 PM
Whitedog's Avatar
pm sent
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
chewy78
Sep 8, 2015 10:37 AM
