06 Dvx jetting question
Old Jan 13, 2007 | 10:50 PM
DVXDUDE's Avatar
Default 06 Dvx jetting question
ok you can see what set up i have by my signiture i'm running a 155 dj main jet and needle on 3rd clip and mixture screw out 1 3\4
bike runs awesome in all gears and rpm ranges, i ran it for a good 15 mintures goin in each gear then i ran WOT for a good 5 seconds then hit the kill switch and pulled the clutch and coasted to a stop then checked the plug, the plug is brand new and there was like no colour to it, tip was a bit burnt but porselin part was white like brand new so it must be running lean still.....header pipe is pretty hot not glowing though ( burnt my pants on the header pipe)
what is the first place to start to look? needle or main jet? and the mixture screw is already in quite a bit, im not messing with the pilot jet because dynojet nor big gun says to change it....
any ideas why its running so lean???
Old Jan 13, 2007 | 10:54 PM
DVXDUDE's Avatar
oya i'm 900 feet above sea level and its cold out right now like zero degrees celcuis....
ANY insight would be greatly appreated i wanna get this thing going by tomorrow before we get a sh*t load of snow
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
