400EX Exhaust
Old Feb 26, 2007 | 08:46 PM
miller3103's Avatar
Default 400EX Exhaust
If i get the LRD which model would I get and do I need the header pipe and rejetting the engine.....which brand would be good? (ex. K&N, or etc?) Thanks
Old Feb 27, 2007 | 04:30 PM
yz426ex's Avatar
LRD you can get the slip on or full system. Full system will be best but most people that dont mod the motor are satisfied with just the slip on.
As for jetting you should be around 160-165.
The air filter that adds the most power is k&n. You will here some people saying k&n lets dirt in but that is not true. It only lets dirt in if you dont oil it right. I used a k&n for 4 years and in clay dust the wors thing for filters and nothing got past the filter. Just use the outer wears boot for added pertection. If you go with a foam filter its not going to really help at all.
For more power run no air box cover or no air box at al like me. if you do that you will need to bump the needle up to the 3rd or 4th position usualy the 3rd.
I never heard any thing bad about LRD except that some peoples headers got wet when it was hot and the coating on the header pealed off and I think they said it startes to rust with out that. if it did happen you could have it coated with some stuff that would make it look good and stop it from rusting.
Old Feb 27, 2007 | 05:14 PM
89exrider's Avatar
If you get the LRD get the Pro4 its a nice pipe. I would also go for the KN filter. All that stuff about the dirt in the engine isnt true. Just clean it and keep it oiled regularly.
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
