piston to bore clearance
Old Apr 6, 2007 | 03:19 PM
Thumper450's Avatar
Default piston to bore clearance
what is the proper piston to bore clearance for an 01 Rancher bored .75mm over and where do you take the measurement on the piston?
Old Apr 7, 2007 | 01:35 PM
Doctorturbo's Avatar
GOT BOOST!
If your running a stock Honda piston, just get the spec's from Honda. If your running an aftermarket piston, get the spec's from that manufacture. The machine shop that is doing the bore job should have these spec's.
Old Apr 7, 2007 | 02:35 PM
BBR650's Avatar
Is always changing bikes.
send the piston to the shop with the cyl. along with the proper ring gap spec. your machinist should get it set up right.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
