Dial-a-jet on my 400ex w/white bros xcr?
Old Apr 18, 2007 | 03:43 PM
hondaguyexsi's Avatar
Default Dial-a-jet on my 400ex w/white bros xcr?
would this dial-a-jet be ok with it or will it be to lean.. i jus heard the dial a jets run kinda lean on most atvs but the do work well
Old Apr 18, 2007 | 10:42 PM
PoolGod230's Avatar
love my dial a jet! I run 125- 6500 elevation with ease. My only words of advice is buy the snorkle kit with it. Good luck!
Old Apr 19, 2007 | 12:53 AM
thanks for the info but anyone else that can clear up how they work on a 416ex..
Old Apr 20, 2007 | 01:31 PM
a little help guys.. anyone used these on 416 or 440 exs???
Old Apr 20, 2007 | 02:23 PM
PoolGod230's Avatar
http://www.thunderproducts.com/dial_a_jet.htm
Copy and paste the link above. I have these on ALL my toys (yes I have a 400ex (440 big bore)) You can install it pro style, like the pic on the link above. Or just tap the intake boot befor the carb. I have done both, boot is the easiest, and only way I have done it for years now. You MUST follow the instructions to the tee. Every bike is set up different, so every dial a jet set up is different. hope this helps.
Old May 1, 2007 | 10:21 AM
2Fast4U400ex's Avatar
I have one you can buy, not sure where i threw the instructions to. I took mine off, I got it tuned on my bro's chassis dyno and it didn't make a difference so I took it off. If anyone wants it make me an offer it's just sitting in my tool box. already has the tapped bolt that goes into the bottom of the carb. Will need a new large zip tie and instructions. That's it.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
