Raptor Stage 2 Cam
Old Dec 22, 2007 | 01:32 AM
Utah_Raptor's Avatar
Default Raptor Stage 2 Cam
I've got a stage 1 cam in my Raptor 660 right now and I want to upgrade to a stage 2. I've got 2 different opinions for 2 very reputable sources about installing this cam:
1 - Install the Hot Cams springs. One or more of the valve guides need to be trimmed down or the vavle seal(s) will be smashed over time. Price i was quoted was $30 to do the work.
2 - Install the Hot Cams springs and you're good to go.
Has anyone installed the stage 2 cam in your Raptor? Did you have to do any work other than the new springs? Any problems if you didn't?
Old Dec 26, 2007 | 02:10 PM
So nobody on this forum has a stage 2 cam in their Raptor 660 huh?
Old Jan 21, 2008 | 05:05 PM
bentagain's Avatar
Mine is an 01 w/ stage 2. Works well. I used kibblewhite springs and did the valve guide machining myself-very easy.
Old Jan 21, 2008 | 05:14 PM
bentagain's Avatar
The guide that needs trimmed is the middle intake. It sits a little higher in the head than the others and therefore gets the most lift from the rocker. I cant remember the amount of trimming hotcam recommends but its not much. It can be done at home with non-special tools as long as you can get the valve out by yourself. Also if you go to a stiffer spring kit you can expect accelerated rocker arm pad wear, but it's not to big of a problem.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
