mini bike modification
Old Jun 28, 2008 | 02:59 PM
4wheeler****'s Avatar
Default mini bike modification
I have a 3.5 hp mini bike that runs great. My question is, if i put a bigger sprocket on the engine shaft and a smaller sprocket on the axle, will the mini bike go faster? Will it be too hard to start up? Any other suggestions on how to make it go faster will definitely be appreciated. Thanks!
Old Jun 28, 2008 | 09:20 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
You could go up a tooth or two on the front or go down a few teeth on the rear that will give you more top speed but I would not do both at the same time.
If you want your mini bike to haul butt you need to look into the COMET CLUTCH System. I have one on a goped I made with a 5.0 Briggs and it will go 55Mph all day long and it will hole shot almost any dirt bike in the neighbor hood you won't believe the differance.
Old Jun 28, 2008 | 09:23 PM
Tpsycho's Avatar
Also on the mini motors check to make sure when you have the throttle twisted wide open that your linkage is actually pulling the throttle on the carb wide open and if you have the pressure type rev limmiter on that motor you can install a lighter spring on the linkage and it will raise your rev limmiter.
Customer Service #1
May 15, 2020 08:46 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
lancemll88
Sep 6, 2015 03:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
