trail blazer problem need help,please!!!!!!!!!!!!!
before last winter i changed the main jet to a 140,& it ran great ,so before for summer i put a 130 back in ,no everytime i give it throttle it bogs down ,if i give it more then a quarter throttle it dies ,can somebody please help me thanks!
I don't think a lack of air is your problem. It sounds more like a lack of fuel. Perhaps when you changed the jet you misinstalled the floats or bent them up. I would suggest that you again remove the floatbowl, adjust the floats (hopefully you have a service manual to get the specs), and check to make sure the main jet is properly seated. I've heard stories of the main jet falling out but I'd imagine that is rare.
i noticed yesterday when i was messing around with that when in neautral i could rev it up ,no prob,but when i put it in gear & tried to give it gas it just boged down,even just giving a little bit of gas it would bog & the quad would barely move,this is what i did there is a big bolt on the bottom of the carb i took it outunscrewed the main jet & put the other one back in,why am i having so much problems,i didnt mess with the needle at all please help thanks!!!!!!!!!!!!
Frisky2050
Apr 9, 2020 11:19 AM
