ESR TRX-6 PIPE FOR 250R
Hey whats up?
I recently purchased a TRX5 pipe which is ment for all around performance.
I used to have a FMF fatty on, and let me tell you this pipes blows it away in every sense.
It gives you alot of bottom, great mid and tremendous top.
Then only complaint that I have about the pipe is where it splits in two. ESR should of "O" ring this, cuz if not sealed propertly it leaves a mess of gunky oil on the frame.
Peace.
Peace.
I am mostly a woods rider that needs alot of bottom end and mid range top end is important but is last on my needs for a pipe as long as the quad will pull the factory top speed with 13/39 gear im happy. the quad isnt that built as far as the motor goes cool head mild midrange port work and a k&n in the box with lid on and stock carb. do you think im asking to much for for a ESR TRX 6 PIPE, WILL IT DO WHAT IM ASKING IT TO DO
Definately. The pipe is designed around the stock gear ratios, and it will pull it no problem. Keep in mind that even though we call this our "low-end" pipe, it still has great top-end performance. Also, all our pipes have a money back performance guarantee, no questions asked (NEVER had to take one back, though!). Let me know if I can answer any more questions, or if you'd like to buy one at a discounted internet price.
-doug, esr
nitereiter@earthlink.net
-doug, esr
I did the entire ESR310 kit with the midrange to topend porting and the midrange to topend pipe. I will say that Doug delivered on every part of what he promised me out of this kit. It is a little more top-end than what I anticipated, but it is exactly what I wanted. Initially, I thought it was very weak on the bottom, but that is because it pulls so strongly from the mid on up. If you are doing woods riding, you would probably want the bottom end pipe. Doug listened and delivered and the ESR pipe is the ablolutely best fitting pipe I have ever bolted on my R. It doesn't move around at all and cleares the frame.
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
