LT500R power valve
I have a 1987 LT 500r and was wondering how much the power valve should rotate on its axis? 5°, 45°, 90°? I know that at 4500rpm the power-valve should rotate seen though the sight glass on the jug. I have seen virtually no movement. The quad is not sluggish just a little raspy at the top end. This leads me to believe that the power valve has little effect on performance. It doesn’t make sense to me. I would think it would run like crap. Any comments are appreciated. Thanks
I had an 89 500, The valve stuck open all the way when the engine was running even at idle , I had to adjust the spring tension to only open at higher revs. It made a huge diffence in power. My memory is kinda vag but i think it turned 90 degrees. Take that cover witht the four bolts and make sure it rotates by hand. Hope this helps.
Hankey Pankey
Jul 31, 2015 05:50 PM
Mojave250A
Jul 11, 2015 10:38 AM
