Mojave Jetting For White Bros Pipe
Old Jun 15, 2002 | 08:08 PM
MOJAVE02's Avatar
i just got a white bros e-series slip-on (12 discs) and K&N Air Filter and K&N Jet Kit. i am at 0-1000 feet. with the filter and the pipe i am currently running a 134 main jet, mixture screw 2 turns out, and the needle on the 3rd clip position. Occasionly the engine will sputter at different RPM's. am i using the right main jet, needle position, and mixture screw setting? or should i change the setup?
Old Jun 15, 2002 | 08:53 PM
mentalmojave's Avatar
I have the the same pipe as you and I think with the 134 you might be better off with your needle on the 2nd clip. I usually run my mixture screw 21/4-21/2 turns out. That seems to work best but I can't share my carb setup since I have a uni clamp on filter and some mild porting I'm running a 140 main with my clip on the 2nd notch.
Old Jun 15, 2002 | 09:15 PM
MOJAVE02's Avatar
thanks for the help.
ltzbrad
Sep 25, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 5, 2015 08:44 PM
