Foam filter vs K&N filter in DUSTY conditions
I would like to get some advice from people who have used both these types of filters. Is a K&N filter any good for a two stroke engine in DUSTY dirty conditions or is the foam filter type best for this condition? I heard that the K&N's are good for 4 cycles(more tolorant of dusty air) and 2-strokes under dune/desert conditions(low dust).
Anybody ever take apart an engine that was run with a K&N or foam air filter and see any internal dirt?
Anybody ever loose an engine from dirt getting inside due to one of these filters?
Thanks,
Rob
96 Banshee
Thanks,
Rob
96 Banshee
I use a prodesign/K&N filter withg a outer wear on my 96 banshee. I run T5's also. I just tore my engine down for the 1st time. It looked super clean in the inside. Reason for taking it a part is getting some mod work done.
So I have had good luck with the K&N
Brian 96 banshee
Brian 96 banshee
k&n for sand and foam for dust. was on the phone with Allen Knowles from ct racing today and he told me that a k&n will pass the smallest particles in dusty conditions. I currently run a k&n on my 400ex and have noticed that if you run a white rag through the boot between the airbox and the carb you will find dust. The reason I was asking him about filters was to get his recommendation for which one to run with his pipe. He recommends a k&n for the sand and races like the baja because a foam fister in a long race like this will plug and then everything passes through
I just redid the top end on my 99 bansee it had a uni foam filter on it first and dirt was gitting in to the carbs.Then I put a K&N filter with the pro designpro flow filter adaptor never seen a spec of dirt anywere not even doing the top end.I hope this has helped you. majicmike
Steeldon
Sep 9, 2015 09:38 AM
