cam for 300 honda
Old Mar 28, 2000 | 05:13 PM
paddler's Avatar
how much diffrence does a 250 sx cam make in the 300 motor,and is there any small thing jet kit ect that would enhance the cam?
Old Apr 2, 2000 | 11:17 AM
partswarehouse's Avatar
WEB CAM makes 4 cams for your 300ex. The first is a cam upgrade which improves overall performance with a .310 lift.Should run fine on your stock quad.----IF you get bigger than that you will need a after market pipe,valve springs.--Even bigger means shortened valve guides,pistons,new carb, $$$$ etc $$$, etc$$$.You will see a huge difference when you start installing cams.It just depends on how much power you can afford!
Old Apr 2, 2000 | 01:25 PM
rhino99's Avatar
Where can you purchase WEB cams and does anyone know the cost?
Thanks
Old Apr 2, 2000 | 04:24 PM
300ex-treme's Avatar
Web Cams is on the 'web' at www.webcamsinc.com. There you will find prices, specs, and company info. I can tell you that they have been around long time as I used to see their adds in Hot VW's about 20 years ago. They have what you need to get your quad to screamer status.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
