400EX swingarm on 250R
Old Mar 30, 2000 | 02:12 AM
CT250R's Avatar
I have an '86 310R and was wondering if the 400EX swingarm could bolt up to it? I notice that it looks close in the front with the spilt mount to the frame but how abou the rear axle carrier width? I want to shed weight as well as shorten the swingarm for better hook. Any help would be great. Thanks,
CT250R
Old Mar 30, 2000 | 02:44 AM
Witz's Avatar
I believe the 400 and 250 bearing carriers are the same. You should be able to slide a 250R carrier in the 400 swingarm without a problem.
Old Mar 30, 2000 | 11:10 AM
JC TRX250R's Avatar
why not just get a used 88-89 swingarm that is already shorter and cheaper and bolt it on. I put an 86 swingarm on mine because I wanted it a little longer for drag racing.
Old Mar 30, 2000 | 11:39 AM
Mr400eX's Avatar
Hey CT,
A 400ex and 250r bearing carrier are interchangeable. You'd very supprised how much is interchangeable. As from the swingarm, the 400 arm doesn't go completely across. Part of the pivot rod passes through the motor, so you'd have to make somesort of aluiminum spacer. I'm not sure have much different the width is at the mounting points. Hope this helps.
Mr_400eX
Old Mar 30, 2000 | 01:12 PM
86atc250r's Avatar
Actually the pivot rod passes thru the engine on both the 250R and 400EX.
The width is the same, the only problem I could see when matching the EX swingarm to my 250R was that the 250R seals would not seal properly on the EX swingarm. I didn't have 400EX seals to see if they would work.
Old Mar 30, 2000 | 02:19 PM
bpace's Avatar
86 and 87 250r's pivot bolt passes through the motor. 88 and 89 does not.
Old Mar 30, 2000 | 02:48 PM
86atc250r's Avatar
Sorry should have been more clear, the original poster was talking about an '86 model....
Good info though!
Old Mar 30, 2000 | 03:11 PM
CT250R's Avatar
Hey Thanks for the input everyone. I found a 400EX swingarm out on the web I think I am going to buy it now.
CT250R
Old Mar 30, 2000 | 07:55 PM
bpace's Avatar
Just a little warning on the 400 swingarm. If you are one who can push the bike to its limits, I would not recommend this swap do to the large problem with the 400 swingarm breaking. We race the GNCC's and have broken 4 of these swingarms in the last year. Just something to keep in mind.
Old Mar 30, 2000 | 10:04 PM
CT250R's Avatar
Well This bike is really just kind of a trail/ dragger bike. I don't really ever jump it. I just want the shorter length and less weight. Thanks for the warning though.
CT250R
