Help,all 2001 Raptor owners
Old Nov 25, 2002 | 02:25 PM
martian's Avatar
Default Help,all 2001 Raptor owners
Could anyone tell me what all Yamaha changed on the 2002 gears?I lost 2nd gear on the 16th of Nov.while riding.Do i have to change all gears and shafts,shift forks,etc? Did Yamaha just add a dogear to second gear or did they change the whole tranny?I called up the dealorship,they told me they were'nt sure about it.(go figure)Thanks for any and all help![img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 25, 2002 | 02:38 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I would say use the search feature here on the forums. I know there is threads that list all the parts numbers needed for the change over.
I find it hard to believe your local Yamaha shop knows nothing about the 2001 transmission problems.
Chet
Old Nov 25, 2002 | 02:59 PM
RIP Dear Friend
try this old thread, you can see the part numbers
This is harder to find than I thought it would be. I know there is better posts about this subject just have to hunt for them.
Chet
Old Nov 25, 2002 | 03:01 PM
martian's Avatar
He did know of the problem,but said they haven't had to do any.He just didn't know if you had to do a complete tranny rebuild or just change 2nd gear and 4th it engages into.I was told they have received no info. on the swap as of yet.
Old Nov 25, 2002 | 03:07 PM
RIP Dear Friend
I remember a list somewhere in the forums that showed all the part numbers needed for the 2002 gear set and it was quite a list.
I am running out of search time. I have to run, but if you don't find it I will try and look later unless someone else finds it.
Chet
Old Nov 25, 2002 | 03:21 PM
martian's Avatar
Chet,thanks for the information.I'll make a call to the local dealer and see what he can get the parts for.Again thanks
Old Nov 25, 2002 | 05:22 PM
RIP Dear Friend
martian,
garyc660R
Quad Patrol, gave me this information. So you can thank him for it.
QTY YAM PART # DESCRIPTION
1 5LP-17401-10-00 MAIN AXLE
1 5LP-17121-10-00 2ND GEAR PINION
1 5LP-17141-10-00 4TH GEAR PINION
1 5LP-17143-10-00 REVERSE GEAR PINION
1 5LP-17243-10-00 REVERSE GEAR WHEEL
1 5LP-17241-10-00 4TH GEAR WHL
1 5LP-17231-10-00 3RD GEAR WHL
1 5LP-17251-10-00 5TH GEAR WHL
1 5LP-17211-10-00 1ST GEAR WHL
1 5LP-17281-10-00 DRIVE GEAR1
1 5LP-18512-10-00 SHIFT FORK 2
1 5LP-17221-10-00 2ND GEAR WHL
1 93306-00427-00 BEARING
1 93102-35393-00 OIL SEAL
2 90201-150U6-00 WASHER PLATE
2 97017-06012-00 BOLT
1 99006-10600-00 CIRCLIP
2 93102-12321-00 OIL SEAL
Also ERAPTOID sent me this message....not sure if it is true or not. He is a good guy though
The '02 parts that you DO NOT NEED are:
Drive Gear 1.........(5LP-17281-10-00)
Reverse Pinion Gear..(5LP-17143-10-00)
Reverse Wheel Gear ..(5LP-17243-10-00)
Hope this helps.
Chet
Old Nov 26, 2002 | 01:03 AM
Ward660R's Avatar
Just in case anybody needs the info again you can find it on Powerrolls web site, but now I can't think of the web site, go figure.
Old Nov 26, 2002 | 09:09 PM
truckracer's Avatar
Website with the part #'s
Powroll
Denny
chewy78
Sep 8, 2015 10:37 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
black_thunder
Sep 7, 2015 01:24 AM
black_thunder
Sep 6, 2015 04:41 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
