250R intake for 39mm carb
Old Feb 12, 2003 | 10:54 AM
havinnoj's Avatar
Default 250R intake for 39mm carb
Hey what should I run so my R can accept a 39mm PWK carb? I have heard of guys using a CR250 intake. What year? I am not worried about using a spacer since there will be no airbox. Thanks.
Old Feb 12, 2003 | 11:36 AM
Spinks250r's Avatar
I just soaked my stocker in hot water then streched it out over my PWK39. It fits fine now even with the airbox and does not leak. Good Luck
Old Feb 12, 2003 | 06:16 PM
DaBeechMan's Avatar
yeah, you can just heat the boot up.
Old Feb 15, 2003 | 09:16 PM
AlkyBurninX's Avatar
Are you running a stock reed cage? If so, you might look to FTZ's intake. It is pretty trick.
Old Feb 18, 2003 | 12:44 PM
Mike330R's Avatar
I use the 1998 CR intake. Got it from CT Racing.
TheHood
Aug 8, 2015 05:49 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Unzzy66
Jul 11, 2015 10:01 PM
