Valve Questions for the 4 Strokers.
Old Apr 22, 2003 | 10:21 AM
voodoo's Avatar
Default Valve Questions for the 4 Strokers.
Heya all, Just a generic valve adjustment question...
I was attempting to check my valves. And was wondering what technique you guys use? IE: A feeler in the middle of the high and low spec, (ie: .007 - .009, use a .008?) slide under and adjust? I am always second guessing it and when i get it back together i think i hear more noise... ! hehe (could be me ole mind?) How much tap is acceptable to the ear?
Old Apr 22, 2003 | 07:52 PM
ftwflh's Avatar
You should be ok at .008 better loose than tight too tight and it wont run good a litle noise and you know they are working.
Old Jul 25, 2003 | 10:04 AM
MOJAVE02's Avatar
if it is between .007-.009 i like to go a tight .009. this is on my mojave of course because instead of the valves loosening and ticking they suck into the head and hit the piston.
Cole Hadden
Jun 15, 2025 09:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
yambam13
Jul 4, 2015 01:49 PM
