Rubberpickle |
04-26-2012 02:27 PM |
2008 Polaris rzr want start please help
My rzr was running fine until I took it through a very deep hole. Although it ran fine until I turned it off. When I tried starting it, it took awhile but it eventually started. I got to where it was dying while it was ideling, although it would start after awhile of trying. This last time It died and hasn't started since. I noticed there was no fire at the plugs. I replaced the plugs and wires and still no spark. I checked the ignition coil by using it on another machine and it started fine, so I know it's not the coil. I'm down to the ECM and I guess he regulator jus not sure if it controls the fireing process or not. It's not the selonoid either cause it's trying to start but It just don't fire off. what else can I try or how do I test the ECM or does the ECM even have anything to do with it. I have power to everything and it trys to start but it just want turn over and the best I can tell there is no fire to the plug. Any suggestions would be much appreciated.
