need help
Old Sep 13, 2013 | 12:42 PM
lv2rc's Avatar
Default need help
I have a 2000 trail boss 325. I put a new foot brake mastercylinder. can not get the brakes to bleed. ive tried mighty vac. and every witch way
Old Sep 13, 2013 | 12:57 PM
scootergptx's Avatar
Supersock
Hired Gun!
Did you bleed from both the rear brake and the main(handlebar) cylinder?
Old Sep 13, 2013 | 01:21 PM
lv2rc's Avatar
Yelp sure did. im about ready for matches and gasolone
Old Sep 13, 2013 | 02:18 PM
Put a little grease around the master cylinder plunger and see if it helps. No telling how long it was in the package and the seal can get dry and hard and seep air a little. I had to use a brake bleeder and at the same time pump the foot brake constantly to first get the fluid and air moving to the bleeder cup . Once you get it flowing you can usually use a wrench and bleed it manually. Just keep the small reservoir full.
Old Sep 13, 2013 | 03:19 PM
lv2rc's Avatar
Put a little grease around the master cylinder plunger and see if it helps. No telling how long it was in the package and the seal can get dry and hard and seep air a little. I had to use a brake bleeder and at the same time pump the foot brake constantly to first get the flutid and air moving to the bleeder cup . Once you get it flowing you can usually use a wrench and bleed it manually. Just keep the small reservoir full.
thanks for the info ill try it
Old Sep 13, 2013 | 03:20 PM
lv2rc's Avatar
Thanks for the info ill try it.
